1975 johnson 70 hp fuel delivery
fireplug
im having a problem getting the engine to pull fuel from the carbs. i checked the bowls and there all full.i checked fuel pressure and it seems to be getting good fuel pressure.i sprayed quick start around the out side areas to make sure there is no vaccum leaks.i had all 3 carbs off and cleaned the jets . theres a screw in the front of the carb and i dont know where its suppost to be set. the engine will run when you spray quick start. any info will be greatly appreciated.
D
DJ
Guest
Re: 1975 johnson 70 hp fuel delivery
fireplug.<br /><br />KEEP THAT STARTING FLUID AWAY FROM THAT ENGINE. It contains no lubricant and will ruin the engine in short order. Best to mix up some 50:1 and put it in a spray bottle.<br /><br />The adjustment screws should be turned out about 1 and 1/2 turns to start.
