porkchop11
Thread starter- Joined
- Jul 13, 2016
- 2
I haven't had the lower unit off first of all. It was working fine no noise no slipping nothing. I had it in a tank cleaning and rebuilding carbs, put it into gear to idle and it just revved no forward or reverse. I took the linkage apart to see if it would go into gear manually and it is very difficult to get it to lock it just clicks most of the time. If I do get it to go into forward it is very difficult to get it to go back to neutral. It did have a lot of play in the linkage under the carbs but i changed the bushings and that helped a lot it went from about an inch and a half of play to maybe a quarter inch. I'm about at my wits end with this motor. I'm starting to think I will have to drop the lower and see if the shift rod is out of wack from previous owner but it wouldn't have worked like it did before right? Any help is GREATLY appreciated
