1975 70hp johnson no spark
secur
Hi I have a 1975 70 hp johnson 3 cylinder.I was going fine then motor stoped like I turned off key now there is no spark.I read other posts with same problem the replys all said to replace power pack or stator. I replaced power pack no help.How can a stator stop spark if it only to charge battery.I have a manual and have performed all tests all are ok Iwill order new stator.But how about the timerbase under stator.I am new to outboardsand would appreaceate any help
adrian bick
Re: 1975 70hp johnson no spark
The stator on your motor does more than charge the battery. It provides the energy to charge the capacitor discharge ignition a seperate circuit. It is easy to trouble shoot. Disconnect the black/yellow wire and give it a try.
secur
Thanks for the quick response I have already tried removing the black and yellow wire still no spark at any cylinder. I also disconnected the red connector and and used switch on starter relay still no spark. all ohm and resistance reading are ok per the manual Thanks
