1975 650 wont start without starting fluid
I just bought a 1975 mercury 650 3 cyl it will not start without a shot of starting fluid. Once it started and warms up runs and starts fine. I checked the compression #1 115 #2 145 #3 140 psi is this far enough off to cause this problem. Thanks I have replaced the plugs as well.
savetexomabeaches
Engines take 3 things to run --- Air, Fuel, Fire --- It runs by adding fuel... So air and spark aren't the issue, its fuel related. Is the choke working?
flyingscott
Compression and spark test need to be done. Have you physically verified the choke flappers are closing or are you just hearing the click.
