George.714
- Jul 6, 2012
- 2
I just replaced the water pump on my 1975 50 HP (50ESL75B - mechanical shift). Many of the posts here were instrumental in my success. Thank you all. When I reinstalled the lower unit and reattached everything, the motor ran great. Water flow from the pee hole was strong and everything looked good. Pat myself on the back for a job well done.
Uh oh. Tried to shift into forward and reverse. Shifted into forward with no problem. Can't shift into reverse at all. Shifted from forward to neutral, but when trying to shift into reverse, wouldn't budge. I didn't want to force the shift lever down and break something.
I'm figuring I didn't connect something right but can't figure out what it is. I've read and researched possibilities and now I'm thoroughly confused.
Was I supposed to put the shift rod into a gear by turning the prop and pulling / pushing up and down on the shift rod? Was the shift lever at the boats helm supposed to be in reverse or forward position? I was very careful not to turn the shift rod when removing or reinstalling. It may have turned 1/2 turn, but I thought I turned it back to it's original position when I removed the lower unit.
Any help is appreciated. Thank you.
