1975-1976 Chrysler 75 hp prop question.
jp101388
I bought a 69 evinrude sweet 16 with a 75 hp 1975-1976 Chrysler motor. Took it out on the lake and it started fine. I immediately noticed the speed was very low, the engine would rev higher but gain no speed my top speed from the start was near 5 mph. Before long i was barely moving. I asked around and received feedback that it was the prop slipping. I had a spare two blade prop and it started out with good speed after cruising around for fifteen minutes I slowly lost speed and by the end of the day i could only go 5 mph at high rpm's. I believe this prop was slipping too. I examined the hub and the rubber fitting was worn on both props. It is a 13- 21 prop with 18 splines. I found that the original prop on the motor was supposed to be 13 by 17. I am looking for a new prop but i don't really know what props i can use and which ones i can't. Any advice would be appreciated.
jerryjerry05
Re: 1975-1976 Chrysler 75 hp prop question.
Welcome, Michigan Popeller will have what you need. Call or send an e-mail with the info you included.
They sell props on this site too.But I don't think they can sell you what you need.Seems they re selling only newer motors props.
Frank Acampora
Those 18 spline thrust pin props are becoming more difficult to find but there are a couple on ebay. As far as re-hubbing them, I don't believe that anyone makes new hubs for them so your only option on your current props is "pinning" them. You CAN pin them yourself with a hand drill and hand tap. Looking at the enclosed photos should be self explanatory.
On these 10 inch bronze propellers I used three 1/4 X 20 setscrews. On your larger props I would recommend 5/16 X 18 stainless setscrews about 1 inch long, secured with locktite. Since your props most likely "plug" into the rear of the gearcase, do not run the setscrews all the way through as I have done with these bronze props.
