1975 135hp Johnson Model 135ESL75E Wont Start
nowher2be
Hello, and I'll make this as short as possible with as much info at the same time. I bought a 1970 Wooden Handmade with a 1975 135hp Johnson Model 135ESL75E and the trailer on the very cheap. Boat is solid and everything electronic works. Everything about this boat was taken care of very well over the years. This leaves me to believe that the handme down went into some hands without very much knowledge when it came to the motor and getting it running.
The starter was burnt, had it rebuilt. The solenoid tested bad and I replaced it also. The #4 coil gave no spark, replaced it.The #3 cylinder plug hole was stripped so I added the helicoil. I now have it turning over in my opinion, like the day it was built. As per the manual, my spark jump is 7/16" on all 4 wires. I sprayed the mix into the cylinders after I gapped the plugs correctly hoping for a pop, nothing. There is a new fuel pump on it, the previous people did get that part right.
I sprayed the mix into the carbs hoping for a pop, nothing. Like I stated, I have the original manual and will go over the fuel system part again before I attempt anything else. The last year on the registration was on 2012 so it was running a few years back. I consider myself very patient and I'm very good at assembling heavy equipment and working on my own trucks/vehicles, so a carburetor rebuild doesn't scare me. Any insight would be most helpful. If it has to go to a mechanic so be it, I've saved quite a bit off that bill already.
One more time, here's the motor - 1975 135hp Johnson Model 135ESL75E
Thank you for any and all advice.
emdsapmgr
If you've got spark and are spraying some gas/oil mixture into the carb throats, you'd think you'd get at least a pop out of it. Makes you wonder if it's actually sparking when cranking it over. That engine makes it's own ignition spark internally, when the crank rotates a minimum of 250 rpm's. If it's cranking less than that, it may not spark. Also, if it's cranking over good rpm's when the spark plugs are out, the cranking rate may decrease somewhat when the plugs are seated back in both heads-the rpm's may drop just enough that it won't spark. Also, that engine will get out of time if the key in the flywheel shears. Once out of time it may pop or it may backfire-indicating it's out of time. The flywheel key may shear if it's not a factory key or if the flywheel nut is not tightened/torqued to 105 ft lbs. After cranking it over, what do the plugs look like? If dry, they may not be getting fuel. If they are wet, they may not be sparking.
nowher2be
Thank you and I believe I understand the sparking sequence and I'm using a brand new battery and my rpm's I believe are high enough for the spark, I've turned this motor over less than a dozen times through all this and when I was finished today the battery still read 12.
I tested the gap with the plugs out one by one with a gap tester set with a micrometer. The plugs are coming out dry, only place I see or smell gas is at the pump and diaphragm.
Is there a test I can do to find out if the plugs are sparking when they're in? The starter is turning the motor over quite strong.
Also, how would i be able to tell if that key is sheared? Everything is turning very sound on this motor, no weird noises, clanking, screeching, nothing. I believe the cylinders are not getting any gas, dry plugs is indicative of that correct?.
Honorary Supreme Mariner
If you spray fuel into the cylinders and then crank it over you should get a pop out of it.---Do you get spark jumping a 7/16" gap when cranking with the plugs in the heads ??
emdsapmgr
You should be able to double check the timing with a timing light set on the #1 or #2 cyls. It should read the normal idle timing, which could be around 4-6 degrees. (each engine is different.) If it's not even close, the key may be sheared. I'd do the test racerone suggests. Put your fuel/oil mix in a spray bottle. Remove the airbox cover and spray it in the carb throats when cranking. That should get fuel into the combustion chambers.
nowher2be
Yes, the plugs stayed in the head during the spark jump test. I put the tester in the boot, clamped it to the head and had someone turn the motor over. All 4 are jumping perfectly. When I did this today I didn't spray very much gas into the cylinders, I just misted them more or less for lubrication purposes. At the same time I thought it would at least try to turn over. When I went with a direct mist into the carbs, nothing. Not the slightest pop towards turning over. Thanks for all the replies. I'll put a full charge back on the battery tomorrow and do this again tomorrow night.
emdsapmgr
As a double check, I'd probably unscrew the bowl drain plugs on the top carb. Then unscrew the main jet that hides inside. (special screwdriver required). Make a visual inspection of those two mains to see that they are clear and not blocked by dried fuel gelatin. If that engine was not prepped for long-term storage, the carbs could be plugged up with up fuel residue. If you see any signs of blockage in the mains, you should consider cleaning both carbs. Also, the rubber parts of that fuel system were never made to handle today's ethanol fuels. I've seen these fuel hoses break down a feed black hose bits into the innards of the carbs, causing problems. Also, likely an original fuel pump bladder is likely disintegrated, requiring replacement or rebuilding.
nowher2be
Thank You very much. Can you elaborate on the special screwdriver. What it looks like and where I can buy one???
Depending on what I come up with today I'll probably order the carb rebuild kits in the next couple days. It didnt seem like gas was making it anywhere past the pump, except like you said, the integrity of the hoses wasn't the best so there was some seepage there.
