1974 Johnson
shooter26
Hello, I have a 1974 25 HP Johnson 25RL74M and when I pulled the lower unit off to change the impeller I could hear a cracking noise that came from the top of the drive shaft, and once it was out some hard black molded plastic chunks fell out. I can look up inside and see more of this broken part but can't get it out. Just wondering if anybody knows what part this is? and do I have to take the powerhead off to get at it.<br />Thanks for your help.
blueboat1
Re: 1974 Johnson
Was it hard plastic or rubber that hardended? there are a few thru holes that have rubber seals/guides that the shaft slides throught. maybe they got old and cracked.
shooter26
Re: 1974 Johnson
I’m sure this is hard plastic (not old rubber) almost a porcelain type hardness.
Xcusme
Re: 1974 Johnson
Shooter,<br />Are you sure the pieces that fell out are plastic?? You mentioned "almost a porcelain type hardness" Use a magnet to confirm that the pieces are not metal.<br />If the chunks ARE metal, they could be the drive splines from the crank. How do the drive shaft splines look??
shooter26
Re: 1974 Johnson
The splines were good (not rounded or scored)I'll check to see if it's metal.<br />Thank You,<br />Jay
