1974 70Hp Johnson, Has No Tell Tale???
Salty Dog
My friend took me out in his 17 Aquasport with a 74 or 75 70 hp Johnson on it. The thing ran great but over heated during a long idle. We ended up replacing the impeller which was shot. My question is can a water pisser be added to this motor. It was strange not being able to see if the motor was pumping water. :confused:
papasage
Re: 1974 70Hp Johnson, Has No Tell Tale???
it should have a heat buzer papasage
papasage
have seen thim added. just drilla hole in the cover on the head or on the side plate . thread to fit a barbed hose conection.papasage
Salty Dog
Thanks, is there a kit from OMC?
papasage
all there is is a barbed hose fitting and a hose . drill the hole in a aproprate place .look at a newer modle it willm give you an idea. 79 has a tell tale.you should have a buzzer on that enguin .it is in the shift-throdle box. you can check it by shorting the beigh wire that goes in the power head or the side cover .papasage
