1974 70hp Evinrude Flywheel won't turn
Jrcrmoore
We've had some issues with this motor, the most recent being a milky white substance in the bottom cylinder. Today we spent the day replacing exhaust manifold gaskets, head gasket, cleaned pistons and cylinders. We put it back together, and it ran rough for a few minutes and then the engine flywheel locked up and it died instantly.
We removed spark plugs and was able to turn the flywheel by hand. Sprayed PB blaster on cylinders to lube it. We cranked engine with no spark plugs, and it cranked roughly and locked up again (with no spark plugs in engine). Now I can't turn flywheel by hand.
Any ideas?
interalian
Milky white substance is oil and water mixed - do you see that now you've replaced the gaskets? The lockup is probably water in the cylinder and you're hydrolocking the powerhead.
gm280
I too would suggest a hydro lock up, but with the plugs out and still locked, doesn't sound like that is the problem. I'l have to keep reading this thread now for the answer. :noidea:
emdsapmgr
It is possible that the rotating assembly suffered damage when the unit hydrolocked. (bent rod, bent piston, etc.) You may need to pull the powerhead down for inspection.
oldboat1
^^maybe consider pulling off the l.u. and see if the powerhead is freed up. Able to budge the flywheel a little, or feels like metal to metal lockup up there?
F_R
Honorary Supreme Mariner
Sorry, I have to bear bad news. Water ingestion rusts and destroys the bearings in the crankcase (before you fixed the leak). The damaged bearings are the culprit now. That powerhead has to be torn down for examination and evaluation. Chances are it is beyond repair or at least $$$$.
