1974 7 1/2 hp Eska water pump replacement question
ibjeepin
Hoping someone knows a trick to get the unit apart to replace the impeller. I have removed the 2 bolts from lower unit and I thought it should just slide apart...but it feels like its got something else holding it......I have used a rubber mallet on it and sprayed pb blaster down in it just in case the drive shaft is seized to the engine but it just wont come apart..........any tricks?
brim_buster
there should be an inspection cover above cavatation plate. remove the screws and take shift rod apart.
