1974 40hp merc 402 lower unit removal
merc1974
I'm looking for a video or step by step instruction on removing lower unit to replace water pump parts can't find instruction in book serial # 7038943.:):confused:
Re: 1974 40hp merc 402 lower unit removal
Remove the bolts / nuts including the hidden one under the trim tab.----The lower unit should come off.----Shift is splined , no disconnect.----------If driveshaft / crankshaft splines are jammed with rust it can be a challenge.
merc1974
Thanks so 3 bolts total and what torque for the bolts
As stated there may be a hidden bolt under the trim tab !----------No torque value needed really.
