1973 johnson 85 hp pee water
mockersonman
My 73 johnson 85 hp dont have a **** water hole. It does not run hot but how am I supposed to know if my water pump is working if I cant see **** water coming out? It is an anniversary edition motor.
alcan
Re: 1973 johnson 85 hp pee water
Hi mockersonman<br /> There should be an over heat light wired to the helm.
D
DJ
Guest
mockersonman,<br /><br />Watch the language, you might get more responses! :(
mockersonman
Very sorry about the language. So what is the correct terminology?
D
DJ
Guest
Mockersonman.<br /><br />To answer your question. There are two holes just below the upper section of your engine on the rear.<br /><br />These are the exhaust relief ports. At idle, your engine should "spit" water out of these. At planing speeds, it sould be a steady stream.<br /><br />If the water pump (impeller) in your engine is more than two years old-replace it!<br /><br />Cheap insurance, let's see,water pump-$50.00., powerhead-$$$$$$$$?
