1973 Johnson 115HP - Need guidance
jm
What should I look for as far as checking it out before I buy. I'm going to purchase a compression guage to check that (please post instructions how to do so.) How much should I look to spend (right now the guy is several hundred over NADA.) I know the electronic choke is non functional. I have seen the engine run. The guy says the compression is 150 +/- 8% all around.<br /><br />Thanks in advance for your advice,<br />John - Temporarily dry docked in FL :(
BKool68
Re: 1973 Johnson 115HP - Need guidance
If you can verify that compression on all cylinders I think you have a good motor there. If you can take her for a ride and see how she starts hot and cold and check max RPM of 5000+ I would try to cut a deal.
jm
Can someone tell me the procedure for checking compression. I bought a compression guage.
