fuzzynugget
- Aug 5, 2012
- 2
I was going to make a long post on here yesterday about my motor, but was fortunate enough to find the problem today. So, this thread is more or less just to help someone if they are experiencing the same issue that I was.
Problem - I had 2 1973 Evinrude "triumph" 65 hp identical outboards. One recently messed up, so I switched out the motors. As soon as I put the new one in and hooked it up, it would not crank the motor over. My key and controls were left from the old motor, so I knew they were good. I changed out neutral safety switch in the controller (and the other switch on the motor as well) the inline starter / key fuse on motor. I also switched out the starter and the solenoids. Still no go, no fire. I checked with meter (grounded to motor block) and was received 12v to the large input post and 12 v to the small "starter" pin on solenoid when the key was engaged. The starter would crank motor over if I jumped directly to it, but it would NOT turn over with the key. Things were really pointing towards the solenoid, even though I was reasonably sure that the solenoid was good. I even took the solenoid from the recently-running motor and put it on..no go. I purchased a new solenoid just to be sure and it still would not crank.
It was then that I had an epiphany, it dawned on me that 12+v on the solenoid doesn't mean much if there also isn't a good ground on the solenoid as well. There were NO other wires (other than hot) going to solenoid. My "old" solenoid had a metal strap on it where it touched the engine block, the new one did not. I quickly ran a wire from the engine block to the "other" small pin on the solenoid...voila, engine cranked over!!! Problem solved, was solenoid GROUND.
