1973 Evinrude 50 will not pump water
coostv
Very long story short, I put in a new head and gasket, impeller, added a telltale output in the head, and a new thermostat in my '73 Evinrude 50hp. It starts and runs fine except it is not pumping water to the power head. I'm running it on muffs and I can feel air coming out of the telltale (and a very slight mist or steam). I've dropped the leg off of it (a few times now) and verified the impeller is in correctly and turning, made sure the water tube was connected to the pump housing, took the cover off the head and removed the thermostat and pressure relief valve out and ran it only to have a couple drops of water come out.
I'm stumped, I can blow compressed air up the water tube and feel it coming out of the newly added telltale, I can also blow compressed air into the pressure valve opening and push some water out the leg. The only thing I have not done is drop it in water and try running it that way, I do not have a container large enough to get it into and frankly don't know if that would even make a difference...
Anyone have any ideas?
Picture, for the heck of it, lol.
y4mwsPIj7c3lSyHsjjp_H-uYnW2F1omwzDjwHMOBcRPmMyo4GsWJBAzUK7wC0LvIJSyxjqlPxXrDvVrez-0Lgd6WF1HVZaVikVqvJd69G249QmpWL6qFEuBOq-ZtxXTRMgewbpOJ1G4xG8dE-H_6WD2rMuMZiK1tRo4HLGQM3DyNiQA5MW8P72paumLG6Zq3RafWIdh6u5DeJzXDnAZzmHdTg
F_R
I have no idea what's wrong with your motor without an on-site inspection. But if I may make a couple of generic comments:
1. Put the thermostat parts back in.
2. You cannot test a water pump by running on muffs. The pump is not pumping when you are doing that--only allowing hose water to flow through. So, get the boat in the water and see if you actually do have a problem or not.
tblshur
+1 on what FR said u sure key is in impeller and impeller fins are bent backwards to the shaft rotation not douting you just something i know dont ask how hope u get it:)
