bruisedreed
Thread starter- Joined
- Jul 8, 2019
- 19
Hello all...just thought I'd pick your brains a bit. I have been lurking a while here and know there is a lot of experience here to glean from. Bought a used 9.5 Sportwin a couple weeks back. Put it through the paces at the house and did all the checks and maintenance items I could before I put it on the water...impeller, lower unit oil, plugs, checked points etc. Runs first pull every time and seems good in about every way. The one thing I can't seem to figure, the exhaust port doesn't spit a stream of water like I'm used to seeing on some of the larger Evinrude motors I've been around. I get very little from the "visual" port really not more than a mist mixed with the exhaust. That said it is a huge port on that with a flexible tube inline to it so I don't expect to see it peeing a solid stream I guess. The motor seems to run cool and vent ports at the around the lower unit spit water. The housing seems to be full. and drains when you shut it down so know it's lifting water at least. I assume it would probably have something to do with the copper tube running up from the water pump not sealing tightly somewhere. What should I be looking for?
