1973 50hp Evinrude no spark
oldboat1
Changed out the ignition coil and that thing fires up on the first turn of the key. 😄 Another problem solved. I hope i dont havr another for a while.
Ha! Went out and found it, couch -- Good sleuthing! Was it that sensor coil you had ordered, or an ignition coil?
Good boating to you.
couch702
Sorry for the delay. It was the ignition coil. I ordered both and since the ignition coil came in first i rolled the dice. And gave it a shot. I knew the ignition coil was bad because i ohmed it out and confirmed it. I ordered the sensor coil as a back up. So now i have an extra part for it. Thanks fir all the help guys.
oldboat1
Think I would use a spark tester on both now, just to be sure. Sounds good.
