1972 Johnson Outboard
clair praught
I have a 1972 Johnson Outboard that has a cooling problem. From standing behind the motor the two cylinders on the right are cooling but the two on the left are not. I believe I may have a problem with the thermostat, and if that is so, where is the thermostat located.
ob
Re: 1972 Johnson Outboard
Clair, horsepower and model no would help.sounds like V-4 90,115 ,140 etc... Thermostats are generally located top of engine block ,rectangular housing with 4 bolt fasteners.
RPJS
Hi Clair<br /><br />On a 1972 V4 motor you will find the thermostat housing on the rear of the motor below the cylinders, a rectangular plastic part with 2 hoses going to it, 1 from each cylinder block, when you remove the cover you will find a spring loaded pressure valve on the left and the thermostatic valve on the right. I have read a number of posts where the spring valve is faulty causing overheating problems.
