carmangary1
Thread starter- Joined
- May 11, 2003
- 52
My 1972 Johnson 85 started running really bad yesterday. Here is a history of what happened:<br /><br />1. Last time I had it out 2 wks ago it ran great. 5500 RPMs on choppy water. Had a problem where there was a loose connection in wiring harness.<br /><br />2. Boat sat 2 weeks outside in Texas heat (covered with tarp).<br /><br />3. Replaced wiring harness. While replacing it, I noticed that blue 2-cycle oil was dribbling out of powerhead area. Not sure why it was so oily (could gasoline evaporated and left oil only?)<br /><br />4. Took boat to lake. Hard to start and sounded like it wasn't running on all cylinders. Finally, got and it running and it sounded better.<br /><br />5. On lake, it seemed to lack some power and would only get to 5000rpms on a smooth lake. It kept getting progressively worse until it wouldn't idle anymore and very hard to get started. It would fire a couple times and then stop.<br /><br />6. Afterwards, if I started the engine and immediately gave it some throttle, it would run but it was obviously not running on all cylinders anymore. Now and then missing cylinder would kick in and it would have a surge of power. Sometimes it would stay running on all cylinders for a long several seconds. Sometimes it would only kick in for less than a second.<br /><br />I tried squeezing the primer bulb and that didn't help. I tried choking the engine while running but it didn't do anything. Someone told me to try that to see what happens but I don't know why.<br /><br />I am thinking it is either an ignition problem or clogged carbs. I have had this exact problem on this boat several times but haven't figured out exactly what the problem is. Usually, I rebuild the carbs, change plugs, and reset the points and then it runs OK. I'd like to narrow it down to the actually cause so that I don't have to keep repeating myself!<br /><br />Also, should there be a fuel filter somewhere? <br /><br />Thanks<br />Gary
