1972 85 hp Evinrude Firing Problems
jdubb1000
This motor will crank up and idle fine but dies when you give it the throttle under load. Its got clean carbs, gas, and points adjusted. Its timed correctly and has good compression. I've been told that it is the amplifier. Being that these things are so expensive, is there any way to rig up a new system, sort of bypass this amplifier?
petryshyn
Re: 1972 85 hp Evinrude Firing Problems
You're right it could be ignition or ...fuel. Try enriching the idle adjustment(back them out 1/2 turn)If this doesn't help check for spark with a spark-gap tester. How far will it jump and what color is it?(bluish white or reddish)....Good luck
