1972 50hp hydro electric shift
dswhit
Is a 1972 50hp hydro electric outboard worth restoring, it has great compression starts and runs, the shift switch is the problem
F_R
Honorary Supreme Mariner
If you know for a fact that the switch is bad, well you'll have to decide what to do. The switch sells for big bucks, around $300. Part number 0385253 (Johnson control) or 0279458 (Evinrude control). Give iboats a call to check availability.
James R
Try to find a used one. Otherwise you need to have lots of affection for that motor to spend the money.
