1972 25hp johnson/evinrude binding crank
Azjohnnyny
I have a 1972 25 hp Johnson Evinrude outboard motor, and I was cleaning out the carburetor as suggested and the engine Seized and would not start after. Since I have taken off the lower unit and the spark plugs none of which Helped. It seems like the crankshaft is binding somewhere I'm not sure what could cause this any help will be greatly appreciated
Honorary Supreme Mariner
You need yo post as much information as you can.----How long have you owned it ?-----Any chance it sat for years and years ?----Any chance it was submerged etc etc !!
kodibass
Master Chief Petty Officer
the underside of the flywheel has magnets, check to see if something has stuck to the magnets and is binding the flywheel (ask me how I know this is possible)
Chinewalker
How, exactly, were you cleaning out the carburetor? You weren't spraying carb cleaner into it while the engine was running, where you?
Azjohnnyny
Well as it was suggested I had put a can of cleaner in with the gas and was running it when it seized, you are not able to turn it by hand in fact you can't even pull it with the cord or anything , you can only do it with a socket and wrench. I went ahead and got the motor completely torn apart it looks like on the upper side of the motor where is the crankshaft is attached to the Pistons there's a slotted mark I'll post pictures I'm not quite sure if maybe the piston became loose so it just went ahead and scraped it or what, it looks pretty bad, not sure if i need a new cover. I have had the boat for almost a year was bought used the motor had 120 compression on both cylinders before this happened now immnot sure because i havent been able to turn it.
Chinewalker
That mark looks like the connecting rod made contact with the crankcase. That can happen one of two ways - either the rod itself comes loose, either by a cap bolt loosening or the bearings within fail. How does the rod cap and journal look on that cylinder?
