1972 25252r kill switch wiring help!!!
awol237
Recently purchased a 72 25hp 25252r. it has all of the electric start goodies already installed but someone has removed the 2 wires coming from the wiring harness to the magneto. Since i can not find the wiring harness that goes up to the console i was going to convert it to a push button start. everything for that is in place as well. What i really need to know is where do those 2 wires hook up on the armature plate/points to ground out the coils when i want to shut off the engine.
thanks in advance.
lindy46
They connect to the points - same place the coil and condenser connects.
gm280
awol1237, Lindy46 is correct. The kill switch shorts the primary side of the spark coils from ever building up any voltage. So even when the points open, there is no voltage transfer to the secondary side to fire the plugs.
Also if you are going to use a Push button as your starting option, make sure there is a neutral safety setup so nobody can even accidentally start the engine if it is in gear. JMHO
awol237
Thanks. I'll put it all together tomorrow. Gm280 I believe there is a neutral safety switch or atleast what I think to be one. It is under the shift lever that limits throttle on the side of the block. It has a wire going to ground off the switch and to one of the small terminals on the solenoid.
awol237
One other thing it has a stop position on the tiller handle by rotating past the slow setting. Exactly how does that work. Does the mag plate touch something and short out or does it just take all the fuel away?
F_R
Honorary Supreme Mariner
As you turn the twist grip it idles slower and slower, until too slow to run and it stalls. It is defeated if you pre-set an idle or trolling speed with the screw on the throttle gear.
kbait
The 'stop' is a throwback to the time before kill switches. You simply turned the throttle down until the motor quit.
awol237
Ok guys,
I connected 2 new wires to the points where the condenser screw. I had spark before the change hooked it to my switch and now no spark. Thought I may have nicked the wire putting it in so put new wire in still no spark. Removed the switch and wires out of the circuit and I have spark. ??????
lindy46
Defective switch? See if you have continuity when not pressed in.
awol237
Switch checked good. As I was taking things apart to double check my stuff I noticed 2 wires off the coils on one side of switch with a ground wire on the other. Don't know what I was thinking but separated the wires took out the ground wire and Wala I have spark again. So this project is now complete. Thanks for everyone's help.
