1971 Merc Distributor Conversion
PreachRick
Does anyone know if they make an Electronic Ignition Conversion Kit to replace the Thunderbolt Ignition? If not does anyone know if I can still get spark plug wires and I think cap for this Merc 1350 model engine ?
Any and Alllll responded truly appreciated !
GA_Boater
Still need the serial number to look for parts. You didn't answer in your other thread.
Faztbullet
No conversion kits...caps do not go bad only carbon pin which is replacable and wire usually good s S/S core but spring burn out in plug boots and these are replaceable also.
GA_Boater
I believe Merc 1350's have electronic ignition.
