1971 Johnson Sea Horse 25hp charging??
im_tawd
Hello, I have a 71 Seahorse 25hp tiller motor. I was wondering if there is any way to create a charging system so i could charge my battery off the motor. It doesnt have electric start, but I would like to charge the battery for the trolling motor, and night lights. If anyone has any Ideas on how to make my motor charge a battery, please let me know. Thanks alot, you guys are alot of help!!!<br /><br />Tawd
petryshyn
Re: 1971 Johnson Sea Horse 25hp charging??
No easy way I can think of...<br /><br />I have seen small alternators out there. If one was persistant enough and had the room, one might attempt to adapt it to the engine....(not an easy task)
im_tawd
Thanks for the reply scematic. But didnt the engine exactly like mine but with electric start have a charging system? Could i find a motor like that and take the charging system off and adapt to my engine? Im not even sure what parts i would have to take off.
petryshyn
Seems to me you have a point type magneto ignition. No room under the flywheel. Some electric start engines did not come with charging systems. I'm not sure if the old OEM external generator found on some relics will bolt up. I guess it all depends on how much trouble you are willing to go through....<br /> :confused:
im_tawd
Thanks schematic, I appreciate your replies. I will check with the local Johnson dealer and see if he has any old charging systems for my motor. gonna cost me an arm and an @$$hole. any other suggestions are welcome. thanks again
