1971 Evinrude 85193A 85hp lower unit cracks
Paulywog0667
No , the cable runs inside the exhaust housing on hydro-electrics.
There's supposed to be an exhaust extension that is between the mid and lower sections of the outboard. Clamps are supposed to hold the wire in place. Seems like a debate for O2 sensors screwed into exhaust manifolds and heat with cars though. Not certain if water pressure from the impeller should really be flooding anything if a thermostat isn't allowing water through.
Wires for exhaust sensors on automobiles are maybe a couple inches away from direct contact with the exhaust.
jimmbo
In the Hydro-Electrics the wires were routed in Midsection in a water filled chamber, that isolated the Exhaust tube(carrying the hot dry exhaust gases) from the midsection housing. The water in this area was always being replaced, so it didn't get too hot.
In the older(1962 - 1968 Electric Shifts, with the exception of the 1968 55hp) the shift wires were indeed routed into the exhaust tube and exposed to the exhaust gases as well as steam. In those engines cooling water was dumped into the exhaust as it left the engine block. If the water pump failed, the wires were, as F_R said "cremated"
Wires for O2 sensors on cars/trucks are never anywhere near direct contact with the exhaust, unless there is leak impinging on them
Paulywog0667
Becouse who doesn't have holes in their exhaust to pull wires out? If I take the tube out of mine the mid section becomes part of the exhaust, but routed from the solenoids keeps the wires out of the blast. If you didn't attach something to the wires while dropping the gear assembly the first time. You might see something mis-routed. The wire hole should be behind and a pain to get to
You're explaining the O2 sensor concept you're debating. The sensor with wires screw directly into exhausts.
Sheathing might melt, but I'd guess the motor melting with the actual wires. There's probably a temperature safety switch on that motor too. The wires are naturally clamped 2-3" out of the blast.
jimmbo
Why would you take the exhaust tube out and run the engine?
Those engines with Electric or Hydro-Electric shifts had temp switches to trigger a horn or hot light, but nothing to shut the engine down. Expanding pistons did that.
Joe Reeves
Did'ya ever have something catch yer'eye and think ta'yourself..... Damn!, wish I had said that!! :fencing: :)
Paulywog0667
I would find a great aluminum cleaner for the weld after making sure the motor starts and has compression.
interalian
Yes, why?
