1970's Mercury Power Trim Problem
SEMOdave
I have a 1972 Mercury 50hp 500 series Thunderbolt outboard. For some reason when I hook the wires for the trim up to the battery the pump turns on and runs the motor up. Can anyone tell me what is causing this??
?----When did the problem start ?----New battery installed ?-----Wiring changed ?---------Without being there I would say the solenoid is jammed.
QBhoy
Sounds like you have mistakenly made the other side of the relay/solonoid live permanently to the battery...or the relay/solonoid has shorted.
SEMOdave
I finally found the problem! I had put a new battery in but turns out the wiring going through the side of the boat up to the switch had fried. someone before me had spliced the wires and did a terrible job. when the coatings melted off the blue wire was touching the power wire. I had ran new wires to the down limit switch but it had been by-passed in this splice so once i hooked it back up the motor would turn on if the switch was closed. Thanks for the responses guys!
