You can find the stuff here on sale.
Click on the "Boat Parts & Accessories) and search for 47-89984 or 18-3017 which are impeller numbers.
At minimum you'll need an impeller, you may need more depending on the condition of the water pump assy. The pump repair kit will include necessary gasket, rubber bits, pump plate, etc, besides the impeller. More expensive kits include a new upper pump body with the stainless insert already installed. If your pump body is in good condition, you can just buy the pump insert and/or pump plate if they're worn.
If you're not in a huge rush, you could pull the lower unit down and inspect the pump, so you'll know what you need.
HTH.........ed
