1970 Sears 7.0 HP impeller replacement
washburn
Removed the screw from the front of the lower unit and got some play but after removing the nut it doesn't want to come apart.
Tried doing a search for help but I'm still hazy. This is the old motor before the twist grip throttle. Model # 217.58531. Is there a set screw on the driveshaft near the clutch that needs loosening? Do I open the gear housing and remove a snap ring? Or do I just beat it into submission with a wooden block? Got the engine running good with a carb kit, just need to replace the impeller and I'll be in business. Just got this motor a few weeks ago for $80. Any help would be greatly appreciated. Thanks.
washburn
(Update) 1970 Sears 7.0 HP impeller replacement
Well, I ended up taking the whole powerhead off and taking the clutch loose from the crankshaft that way. After soaking for about a week I finally got the driveshaft and clutch apart. There IS a spline that will come apart. Also, discovered that the clutch itself will UNSCREW in (2) pieces. So, if you have problems like I did on this same model this is an option. There was too much corrosion on this motor. Now I wish I had left the lower unit alone and just ran it. Anyway, I've got some new gaskets on the way so wish me luck.
Washburn
Re: (Update) 1970 Sears 7.0 HP impeller replacement
i have the same motor may i ask where did you get the carb kit and other
parts. thanks fixeruper
