1970 sears 5 hp shuts off after warm up
donaldjoynerga
i have a 1970 sears 5 hp outboard that wont run after it warms up,i put a carb kit and new points and condencer in it and i still dont run right i was wondering if the water pump would be the problum even if it only cools the shaft would it cool the motor as well,also dont know if i have the carb tuned right.
M
mrcrabs
Guest
Re: 1970 sears 5 hp shuts off after warm up
your misinformed as to the water pump only cooling the shaft, think of it as a heat sink for the whole air cooled engine....its the combination of air and water that cool this engine, the water through the adapter plates under the actual engine, newer model AV 817s had a casted in water jacket beneath the lower half of the cylinder, yours does not but works as I have stated and is critical to the life of your lower crank bearing and seal, also water is circulated around the exhaust port via the base plate helping to cool the exhaust ports and prevent piston scuffing.
Your problem could be several things from bad fuel pump bladder and or stoped up fuel vent, plugged up jets or fillter screen to leaking crank seals. If its been abused and run with out the benefit of water circulation I would bet the lower seal is leaking for sure:)
donaldjoynerga
thanks ill look in to that i try it again today and it did the same thing when i dies it will not crank back up unless i choke it and it will then run a short time but never gets to full throtle,the carb i have does not have a fuel pump or any screens there was very little to replace when i rebuilt it,i never checked the compresion i never thought it would be the problum but now im checking every thing.:confused:
donaldjoynerga
also smoke comes out the carb when it dies,dont know if that is normal
