1970 Evinrude 9.5 Carb cam not right
motorguru
Motor is a 1970 9.5 Evinrude. The problem is the throttle cam that opens the carb. First it seems that it should have a vertical roller that opens the carb butterfly and it has a horizontal one. Also the butterfly opens in the opposite direction than the cam would push it open. (a downward or outward force is needed to open the butterfly). I can adjust the carb end by pushing it inward and pulling it back out. I'm not sure if your supposed to be able to do that, I'm guessing it's stripped but I can fix that once I get this figured out.
One other thing. The low idle flexible cable is attached to the jet but isn't attached to anything on the knob side. It turns easily but doesn't attach to the knob. Not a big deal as I can adjust it once and leave it.
F_R
Honorary Supreme Mariner
Vertical cam follower is part number 310001. Is it missing?
F_R
Cam pushes on cam follower. Cam follower pushes on throttle shaft lever.
motorguru
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
motorguru
evin1.jpg Here is a picture. To open the carb butterfly the lever has to push towards the engine.(left)
F_R
For one thing, the lever on the throttle shaft is upside down. Rotate it 180 degrees. I dunno, I think I see the plastic cam follower below it, but it doesn't look right if it is. It should be pointing upwards to contact the cam
If you PM me an e-mail address, I can reply with the instructions.
motorguru
Thanks for the help. Once I turned the throttle shaft end 180 deg. and fished the cam follower out that was pushed all the way rearward. It makes sense.
