1970 6hp Ward tune up questions
GreenHornet763
Model is vwb27006a
What plugs do I need? rh12,h12, j10
What is the gap for plugs and points be? .3 & .2?
What is the torque lbs when putting back flywheel?
Thanks
GreenHornet
wickware
Re: >>>>>1970 6hp Ward tune up questions <<<<<<
My Clymer manual does not seem to have your specs but I did see some info @ the address below that I feel will help you. Such as: 5 or 7.5 HP Sea King vs 6 HP, points .020, plugs .030 and other info. 40-45 ft lbs was the flywheel torque I saw searching this site. Searching this site will possibly give you direct info. jow
http://www.marineengine.com/cgi-bin/discus/show.cgi?tpc=2&post=64328
M
mrcrabs
Guest
go to www.sparkplugs.com
they have a marine application menu
Jeremy T
Just put a wrench on the nut and wack it a few times with a hammer. "Joking" lol
M
mrcrabs
Guest
should be about 35-50 ft lbs or good and tight which ever works for you.
GreenHornet763
Got the flywheel off using a puller. Set the points but no spark. Turns out i was turning it the wrong way :palm: Turning it counter clock instead of clockwise but it's a lesson learned lol. Time for new lower gear unit oil and try to clean the carb. Next question
Compression was at 60lbs #1 and 58 #2, is that to low to start?
M
mrcrabs
Guest
put some gas and oil mix in a squirt bottle and give the cylinder a few shots and check it again
GreenHornet763
I got it started today along with new 92octane gas @24:1 ratio and new fuel lines. A few problems, water pump doesn't pump water and heads get hot. Also will not run at WOT, only partical throttle. quesitons
What can cause it to run only at partical throttle and not WOT?
What is the impeller number for replacement?
