1970 60HP Evinrude
ice_667
This motor has given me all kinds of trouble and I've only had it for a month. I've got it running good, but it will only get up to 2700 RPM. The carbs are tuned the best I can get them, I replaced the points and coil pack , the rest of the electronics are fairly new,compression is good, and the fuel pressure is good. Don't know what else to do. Any help would be greatly appreciated.
krosemond
Re: 1970 60HP Evinrude
Will it rev higher than that in neutral not under load? If so, I would make sure it is propped correctly for the boat and normal load.
ice_667
It will only rev a little bit over 3000 in neutral, so the prop shouldn't be the problem. Thanks
