197? johnson 7.5 dies at full throttle
hambleton
My Johnson 7.5hp will tool along just fine for hours at trolling speed. If I open up the throttle it goes great fro a short time then bogs right down. If I back off the throttle quickly I can keep it running. I can nurse it along like this for a while an then It will allow full throttle for a short time again, although it does not seem to go at full speed. Yes tank is vented and fuel is fresh, plugs are new. Can anyone help?
JB
Re: 197? johnson 7.5 dies at full throttle
Sucking for fuel at high speed.<br /><br />Clean the carb bowl and hi speed jet.<br /><br />Check all fuel lines and fuel pump for restrictions or air leaks.<br /><br />Let us know what you find. :)
