1969 johnson seahorse 6 points settings
jfatheree
is there any special position where I should set my points at?? confused because i see a "B" and a "T" setting on my flywheel. motor starts at full throttle and runs ok there--cuts out and misses at low rpm. i know to set gap at .020, but what other info should i have? -- ps.--<br /> is there an electric starter kit for this old beast?
rwise
Re: 1969 johnson seahorse 6 points settings
jfatheree <br /> Welcome to the board.<br />turn the flywheel until the points are at the max open position, adjust them there. I don't know about a starter kit. Have you cleaned the carb/s?<br />And disconnect the spark plugs before turning flywheel for safety!<br />Richard
