1969 Johnson 9.5 model 9R 69S
sosinski
I just purchased this motor and there is a button that says slow speed adjustment. Of course the button will not stay on and the stem moves in and out of the housing. What position should this be in when starting the engine? Thanks<br /><br />Steve
digimortal777
Re: 1969 Johnson 9.5 model 9R 69S
is it the mixture adjuster on the front of the engine or the one on the side<br /><br />all the one on the side IS FOR IS ADJUSTING TROLLING SPEED<br />FROM CLOSED THROTTLE TO ABOUT 1/8 THROTTLE<br /><br />to start the engine turn the knob all the way anti clock wise then turn it back in about 2 or 3 turns<br />then once you get the engine idling adjust it whatever way you like it
oldboat1
A parts manual would be helpful to you -- would show you how the low speed needle is attached. The needle (the long stem that seems to be loose) screws into a housing which in turn screws into the carburetor. In addition, there should be packing around the needle that secures it in place as you screw it into the housing. If the packing is missing, the needle will move around in the housing -- as may be the case with your motor.<br /><br />I would back out the needle (counterclockwise), then do the same with the housing -- and both may in fact come out together. The needle should have a nice point on it, with no grooves. You can carefully clean it with a piece of fine sandpaper or steel wool. You would reassemble by first screwing in the housing, then screwing in the needle with the packing in place (resemble O-rings that fit over the needle shaft). Seat the needle gently (clockwise). Initial adjustment for starting is probably about 1 and 1/4 turns out (counterclockwise).
sosinski
thanks to Digimortal777 and OldBoat1 for their advice..will try same this week.<br /><br />Great Site!!<br /><br />Steve
