1969 Evinrude Starflite 85hp Stuck in Forward or reverse, no Neutral.
bcvizina
I started my boat with the remote control in the neutral position. I was at the launch with my boat still on the trailer, when I noticed it was in forward gear.
I toggled the remote to forward,, but still no change. I tried reverse and it definitely engaged reverse, so I toggled back to Neutral quickly, and it went back into forward gear.
Back story:
I recently replaced the water pump and impeller unit. I bought a service manual off eBay and read through each relevant section until I thought I had it under control. Disassembly and reassembly went more or less as planned. I put new gas and oil in, took it to the launch, and now I'm back here.
Also, this boat was in working condition last summer. Late in the year the impeller went bad while in idle, and I noticed it right away and avoided any serious damage.
I didn't think I would have made any changes to the gearcase or shifting? I haven't checked the gearcase oil. Maybe the shift connectors to the lower unit are loose?
Joe Reeves
Read the following through a few times so that you thoroughly understand the lower unit electrical shift setup.
In reverse, you are obviously getting 12v through to "both" shifting solenoids... BUT... in neutral you are obviously NOT getting 12v through to that one coil. This indicates that the neutral button/switch is not supplying 12v to the solenoid.... broken wire, bad button/switch?
(Hydro Electric Shift System Explained)
(J. Reeves)
NOTE 1 -The ohm reading of the individual shift solenoids should be between 5 to 6 ohms. The ohm meter should be set to low ohms. The shift wires leading to the solenoids must be disconnected when being tested.
NOTE 2 - The solenoid plunger measurement must be made with the solenoid placed within the lower unit. The measurement must be approximately 1/64" beneath the top surface of the solenoid... NOT above the solenoid surface nor any lower than 1/64" of the solenoid surface. This factory measurement is critical and will not ever change UNLESS someone has tinkered with it.
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
Note: The engine must be running OR have the driveshaft turning by some other means in order for the engine to shift.
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
F_R
Honorary Supreme Mariner
Until proven otherwise, my guess is you have a bad shifter switch in the remote control. Prove it by the jumper wires just described.
