1968 Evinrude Fisherman 6hp (midsection question)
Nipper
I have a 1968 Evinrude 6hp Fisherman with an extra long shaft. In the midsection there is what appears to be an extension. Does anyone know if this extension can be removed to make it a short shaft? I have not opened it yet and I'm wondering if the drive shaft and water tube inside might be extensions as well?
oldboat1
better to get a reg shaft parts motor (eg. short driveshaft costs about $240.)
clemsonfor
Yea, pull that section out, get a short shift shaft, short driveshaft, short water tube and short exhaust tube. But as said it's probably cheaper to get a short shaft parts motor.
Nipper
Where are all these "parts motors" you speak of?
Has anyone actually opened one like mine that can speak from experience?
Honorary Supreme Mariner
Depends on your location.----Lots of parts motors in my area.
F_R
I have actually opened many of them, back in "the day". To convert yours to short shaft you have to find a short drive shaft and short upper shift rod. You can cut exactly 5" off the water tube.
For parts your best bet is a want ad at the Antique Outboard Club's website www.aomci.com Ad is free. EDIT: Make that .org, not .com
clemsonfor
I just rebuilt a 1973 25hp long shaft. NO it's not the same engine and lower, but VERY similar. All these engines have literally about the same parts. They have to have all the same stuff. They all have water tubes drive shafts and shift shafts. You can buy it piece meal off eBay useing short shaft part numbers but chances are you will pay as much or more than buying a short shaft motor and swapping parts. Go to old school marine mechanics or guys into vintage stuff. They will possibly have them laying around.
