1968 Evinrude big twin
Shaffer89
Hey! I have a 68 big twin on a boat I recently purchased. I was told the boat had some wiring issues but my brother and I went through all the wiring on the boat, lights, horn, fish finder ect. And we have everything working now. But when we tried to fire up the motor nothing happened we checked to see if the motor was seized but everything moved smoothly. We jumped the starter and it worked fine, so we figured the solenoid was bad. I put a brand new solenoid on today and still nothing! I would say the ignition switch works cause when the key is in the "on" position you can flip the choke switch and hear the choke moving in the motor. I figured maybe either the ignition switch's "start" position could be messed up, or the wiring from the switch to the solenoid might have a short? Any ideas or suggestions?
F_R
Honorary Supreme Mariner
Your story is so classic, and I've heard it so many times. Forgive me, but I gotta ask---that new solenoid you just put in, is it the correct one, or did you go to the auto parts store and get a car solenoid that looks exactly alike? If you put in a car solenoid, take it back out and put the original back in, at least till you prove it is bad. And if you do prove it is bad, replace it with the correct type. If you have a car solenoid in there, you have two problems, the original problem, plus the incorrect solenoid problem.
OK, preaching is done now, so on to the question. Don't guess--test!! Do you have a voltmeter (multimeter) and do you know how to use it? Check the voltage on the two small posts on the solenoid while a helper turns the key to start. Should have battery voltage on one, and zero voltage on the other, and solenoid should click, and starter should run. By "voltage" I mean +tester lead on one post, - lead on ground
1. No voltage on either one, problem is ahead of there. Wires, key switch, battery, battery cables, etc.
2. Battery voltage on both, solenoid does not click-- Safety switch is shot OR safety switch is out of adjustment OR throttle is advanced beyond "start" position. BTW, if you had a car solenoid in there, you probably destroyed the safety switch.
3. Voltages are as they should be, but solenoid does not click-- solenoid is bad. (This scenario is very unlikely)
4. Voltages are as they should be, solenoid clicks, but starter does not run-- Solenoid is bad OR starter is bad, OR battery OR battery cables are at fault. Includes battery cables connections. Don't just look at them, take them off and clean them shiny bright and reinstall tightly.
Shaffer89
Thank you, I'll get started on that and post later what I come up with. I ordered the solenoid online using the exact part number of the one that was already on the motor so I doubt it is a car solenoid. The old solenoid look like it had juice or corrosion that had leaked out of it, that's why we figured it was bad.
Shaffer89
Update: I went out this morning and messed with it and double checked all the wiring was tight and in the right place. Everything looked good so I put the throttle to the start position and made sure it was in neutral, hit the choke swirch and turned the key and boom she fired up. Not sure what I did exactly, maybe it wasn't all the way in neutral or maybe the throttle wasn't all the way in the start position but now she fires right up!
F_R
Sounds good. You might want to take a look at the safety switch for any problems there. It is on a bracket up under the magneto plate that rotates as you operate the throttle
