1967 mercury 110 9.8 water pump
Swampy54
Where is the water supposed to come out of from the impeller? I don’t see a hole anywhere for it to come out.
hardwater fisherman
I do not know that motor, but being that old there may not be a "tell tale". Someone else here should know.
it comes out the exhaust
however if you just bought the motor, you should be doing an impeller change prior to use anyway.
Texasmark
If like later model engines, and no reason why it would be all that different, the impeller is in your water pump assembly which is just above where the lower unit and mid section join.....the pup is attached to the lower unit, and can be seen on top of it when the lower unit when removed. It receives it's input water from the small holes in the lower unit housing.
The output of the pump is on top of the pump casting and via a copper tube goes into a grommet in the bottom of the engine block. In the engine block it cools the engine and in discharging, cools the midsection of the engine and exits the center of the prop......through hub exhaust system.
Just below the cowling on the rear of the engine are ports that allow "exhaust gas relief" for when the engine is running in the water and the boat isn't moving....some cooling water may come out there also , with exhaust gassesamount depending on engine rpms.
There is a small tube that runs from the exhaust manifold (flat plate on the left side of the engine viewing from the rear) over to the other side of the engine and just below the cowling exits a stream of water when the exhaust manifold has enough water pressure (from filling with water from the pump) to force water out.
MTboatguy
I know for some reason on my 69 Merc 110, the mud wasps love to plug the tell tale tube up with mud and I have to unplug it every year.
