Re: 1967 johnson 40 hp electromatic wont start at the key switch
So what led you to believe the solenoid was bad? Jumping to the ignition switch is also not troubleshooting. You first determne the part is actually bad (troubleshoot) then replace it if it is.
1) Is the battery fully charged? Verify -- don't just say yes.
2) Are the battery cable connections clean and tight. Again, disassemble, clean (as in shiny bringht on both ends) and tightened securely?
3) Using a test light or meter, have someone turn the key to START while you check for voltage at the "S" terminal on the solenoid. That would be the small terminal coming from the ignition switch. Voltage? Yes or No
4) If yes you have a bad starter, bad solenoid or bad connectiions between solenoid and starter. You can rule out the starter by shorting the two large terminals on the solenoid with a jumper cable or large screwdriver. If No - you have a bad wire from the "S" terminal on the ignition switch, 12 volts is not reaching the ignition switch (red wire on the "B" terminal) or the switch itself is bad.
5) The "B" terminal on the switch should have 12 volts all the time. If not, fix it.
6) The "S" terminal should have +12 volts when the key is turned to START. If not, the switch is bad.
Warning: Doing this series of tests in a helter skelter fashion proves nothing and you will chase your tail as well as replace parts needlessly. Do them in the order listed.
