1966 3 HP Evinrude Getting Hot
special_ed_phillips
My 3 Hp Evinrude that I put a new piston/ring in seems to be getting hot. I am mixing my gas/oil to 24:1. Someone at another help sight said he thought there was a screw/bolt on the side of the engine that you could take out and see how the water pump is pumping. Does anyone know about this? Also, I took the head off the shaft and checked to make sure nothing was stopped up it did not appear to be. Any help would be appreciated. Thanks ED :)
Solittle
Re: 1966 3 HP Evinrude Getting Hot
Put in a new water pump even if you think it might not need it.
Paul Moir
The screw I think buddy was talking about is a big slot screw just below the head. It's the flush attachment point. Water should shoot out a couple feet with it removed. With the screw out, I doubt the engine will see much coolant, so make the test brief (or without spark).
Xcusme
ED,<br /><br />Just a couple of things.....Did you check the ring end gap before you installed the new rings?? When you say , "Also, I took the head off the shaft and checked to make sure nothing was stopped up it did not appear to be" What shaft are you talking about??<br /><br />Testing the temperature of the motor on top of the head will be considerably hotter than testing on the side of the block, this is normal. If you can't leave your fingers on the side of the block for more than a few seconds, it's running too hot. Start looking for any obstructions in the water passages or the water pump impeller.<br /><br />Usually these smaller motors will not have a 'pee stream' or tell-tale to verify the water pump operation. They can have small vent holes in the lower leg , just below the powerhead that sprays water when the motor is running. If your hand gets wet when you hold your hand near these small holes , your pump is working. If in doubt, drop the lower unit and using a small rubber hose connected to a garden hose, force water up the copper water cooling tube to verify water flow thru the powerhead. Check the condition of the water pump impeller while you've got the lower unit off too.
