1964 Johnson 9.5 hp
Davemld
I bought a 1964 Johnson 9.5 hp today for $30.00. I got it from a doctor who was trolling with it and knocked it into reverse with the butt of his fishing rod. Since then it pops out of gear. He said last time he ran it, it went for 15 minutes then poped out. He looked at the gears and said they all looked good. He could not get it started this year and decided he was done. I took it home checked the spark and the spark was good, compression 60 in both cylinders. So I cleaned the plugs and fired it up it started in four pulls after that it fired up after one. Came with the metal tank line and bulb so there is $30 right there. Just wondering if anyone has any suggestions on what the problem is with the lower unit.
Waterfowlnut
If he was trolling with it when it accidentally got knocked into reverse it shouldn't have really hurt it. Have you tried running it and shifting it in and out of gear?
Davemld
No I checked the prop pin seems ok. I am going to take it out today and see for myself what is going on. In gear I can turn the prop with a little resistance in forward and reverse, I shouldn't be able to do that. I'm wondering if its the monkey clutch?
emckelvy
You may have to pop the gearcase and carefully inspect the clutch dogs, and also reverse gear. Every time it jumps out of gear those parts are damaged. Also inspect the shift fork that slips over the dog clutch, it's only aluminum and sometimes you'll see 'em all worn away on one or both sides.
Another thing to look at on these old 9.5's are the motor mounts. Especially the front mount. If the mount screws are loose, missing, or the mount is busted, the entire powerhead/midsection/gearcase assy will rock back and forth inside the motor casing.
Since the shift linkage is mounted on the motor casing, this either puts tension or compression on the shift linkage and can cause the motor to pop out of gear.
Lots o' Fun changing the mount if it's bad, you pretty much have to take have the motor apart to get at it!
But these old-timers are really nice runners once they're squared-away. Just a wee bit on the complicated side for the mountings. But hey, it runs and has a tank, how can you complain for the price! Lots of parts on eBay if you need anything, or out of the local Craigslist.
HTH & G'luck.......ed
Crosbyman
make certain the shift rod is properly screwd down in the shift rod connector
had trouble with my 1966 9.5 recently (no forward ) and had to adjust the shift connector where the top and lower shift rods meet
lindy46
Make sure the pivot pin is in place and passing through the hole in the fork on the end of the shift rod. That pin is the Phillips head bolt on the skeg. I've seen them removed by mistake and not put back correctly. That can cause your shifting problem.
