I've got a 1964 Johnson 65 HP that won't shift. I removed the lower unit, and the driveshaft will spin, but the shifting rod seems stuck. What should my first course of action be? Are special tools required? The gearcase does not appear cracked, although it was pretty much dry when I opened the drain screw...
Also, how hard is it to line up the distributer and the flywheel to correctly time this engine? I found a line on the distributer pulley, but I don't know where to line it up with. I took the belt off to clean the points, and somehow lost the placement. I also may need new spark plug wires, but finding threaded ends is turning out to be more difficult than I thought. Thanks in advance!
