1964 Evinrude SPARK PROBLEM
wenham
How do i check the points and coil without taking the flywheel off<br />The plugs appear to have a small spark on the block test No starteee<br />is there a dea<br />d switch or wire to connect that may be causing to trouble The outboard is not on the boat<br />Ta :confused:
ob
Re: 1964 Evinrude SPARK PROBLEM
wenham,You have to post what size motor you got.The help you get is in direct relation to the info provided.
