1964 Evinrude 40HP Electric shift-- IMPELLER
JPCAN30
hello, im new to this forum as i cant seem to find any information on how to replace an impeller in a 1964 Evinrude 40HP with Electric shift. is there anyone out there that can point me in the right direction. i have been able to pull the cover off the motor and pull out 6 bolts + 1 longer bolt and drop the leg down an inch or so but do i need to have the motor in gear if so then what direction? thank you in advance.
JPCAN30
yes i have disconnected the wires, however do they come out with the lower unit? also does it need to be in gear?
F_R
Honorary Supreme Mariner
You have to remove the inspection plate from the side of the midsection, then you will see the wires inside. Assuming you disconnected the wires at the top, fish the cable out the hole you just uncovered. Now remove the two bolts from the smaller cover inside and pull it off the cable (squirt some oil on it first). NOW you can remove the lower unit.....AFTER you tie a string or something to the wires to aid in pulling them up through during reassembly.
JPCAN30
F_R, thank-you for the help! does the motor need to be in Foward or reverse to remove the lower unit?
F_R
Makes no difference. Actually, the shift is disabled when the wires are disconnected.
JPCAN30
Fantastic! thank you so much for reading this forum and responding. i will post an update next week once the work is completed.
You have to remove the back half of the lower cowling to find one large bolt !
JPCAN30
Racerone...... thank you, i have removed all cowling and all bolts...
