Seahorse669
- Jun 19, 2012
- 9
Hello, I purchased this motor from a friend last summer. He said he had started it up just before i picked it up. I put it into my dads basement untill this summer and decided to try it out. Since it was in running condintion, i figured i'd just put new plugs and new lower unit oil it it. (1963 Evinrude 18hp electric start). Well, as soon as I took the screws out of the lower unit nothing but water came out, I'm thinking that's not good. I filled up the lower unit with oil anyway. Then I tried to start it and it wouldn't start. No spark. So thats when I discovered this forum and ordered some stuff. I ordered a lower unit seal kit, a water pump impeller kit, carberator kit, points and selenoids. Like I said this is my first outboard motor and i'm getting in deep here, but is there something else i should be looking at as well? For those gaskets do you use regular gasket goop?
