1962 Johnson FD-16a 18hp cooling problems
lorenz316
i have my new motor running great but it wont pump water. ive replaced the impeller and thermostat. i ran water back down the lines from the thermostat port and it comes out both intakes and the exhaust. i tried flushing water up the copper tube from the impeller and it comes out the thermostat port. i cant figure out what to check next. im a novice mechanic so any suggestions would be greatly appreciated
F_R
Honorary Supreme Mariner
Make sure the stainless steel plate in the pump is sealed to the gearcase (no crud under it either). Make sure the pump housing isn't excessively worn. Make sure all 3 screws are tight (none busted off and ignored). Make sure you hit the grommet hole with the water tube. And most importantly as already said, make sure it is deep enough in the water. It is unlikely that it is plugged up unless it is a salty dog.
tomhath
Master Chief Petty Officer
A head gasket is cheap. Pull the head and see if the passages are blocked. Then run it deep in the water at fast idle for a few minutes so it warms up enough for the thermostat to open.
