1960 RDS-22 Johnson 40 HP No spark!
crkistler
New here, and brand new to boat engines.
Just bought a 16' fiberglass boat w/trailer, and the 1960 Johnson motor for $600. I paid $4.95 and downloaded the service manual and its a little too much info for me to digest right now.
So my problem is I'm getting no spark in the spark plugs......I have gas pumped into the fuel lines and fuel bowl but I'm not getting spark nor do I smell gas on the plugs (plugs are brand new and gapped 0.03). I do NOT have the external wire harness and I'm concerned the electrical system is stuck off??? I can't figure out how to access the coil under the fly wheel, maybe the coils bad?? I'm stuck and I admit I really don't know what I'm doing. Any suggestions would be much appreciated!
Thanks in advance.
Honorary Supreme Mariner
Fact-----You have to learn to do the work yourself.-----Most shops will not work on it.----If they do it is big $$$ for those who are on a tight budget.--------Remove recoil starter.------Remove inspection port on the flywheel and have a look at the 2 coils in there.
F_R
If they are the original coils, you can bet the farm that they are bad (cracked). Get new ones here at iboats. You will need a 3-bolt puller to get the flywheel off and a Torque wrench to tighten the nut to 100-105 ft/lbs when you put it back on. You must do it right or it will cause $$$ damage to the flywheel and/or crankshaft.
crkistler
I'm planning on learning how to work on these outboards....I just need to figure out the basics and I'll be good. Kinda scary taking apart something with so many parts and pieces for the first time. I did open up the inspection port and rotated the flywheel and looked at the coils and everything inside......everything looked brand new and clean. How could I tell if the coils are bad? Guess I need to start reading and researching.
crkistler
I guess I didn't really look for cracks, they looked clean as hell so I thought "everything looks good in here". I'm gonna give them a closer look.
F_R
No Title
Maybe you got lucky.
lindy46
If the coils are not cracked and appear to be replacements, then go ahead and check the point gap right through the inspection port. They should be .020". If not you can adjust them by turning the little screw to the left of the point set until they are .020". Then CLEAN THE POINTS! File them with a point file or use some 200 grit wet/dry sandpaper. Then cut strips of a business card and dip it in acetone and work it back and forth through the gap in the points. Now check the spark with a $10 spark tester available at any auto parts store. SPark should jump a 1/4" gap with a snappy blue-white spark.
crkistler
I finally got a chance to take another look inside the inspection port.....I looked at both coils and they both have what looks like a seam in them......not a crack but a seam. Would a coil have a seam??? If not they both have a perfectly straight crack in the same place. Wish I would've taken a picture but didn't..boat is not at my house.
lindy46
Coil covers have a seam - you will know if they are original/bad - will look like cracked/shattered/broken plastic.
